It is currently Fri Nov 06, 2026 2:38 pm
Have you/company/clients used remote operation to increase distance.
Yes 58%  58%  [ 18 ]
No 19%  19%  [ 6 ]
No but considering it 23%  23%  [ 7 ]
Total votes : 31
 Post subject: Use of Remote Operation to Increase Distance?
PostPosted: Sun Apr 24, 2022 1:30 pm
It is well known that the further a person is from an arc flash, the less the incident energy exposure is.
There are many devices available on the market to increase this distance via remote operation.
Yes
No
Please share your experience!
 Post subject: Re: Use of Remote Operation to Increase Distance?
PostPosted: Mon Dec 29, 2025 8:24 pm
Regarding arc flash and safe distance, I've participated in projects using remotely operated medium-voltage circuit breakers. Experience has shown that increasing the distance significantly reduces the risk to technicians during operation. However, the initial investment cost is quite high, so it's usually only applied to areas with high incident energy. According to IEEE 1584 guidelines, distance directly affects the level of exposure.
Among Us
