It is currently Mon Aug 17, 2026 12:59 pm
Do you/employees wear arc rated PPE below incident energy levels of 1.2 cal/cm2?
Yes 63%  63%  [ 17 ]
No 15%  15%  [ 4 ]
It Depends 19%  19%  [ 5 ]
N/A 4%  4%  [ 1 ]
Total votes : 27
 Post subject: Arc Flash Below 1.2 cal/cm2?
PostPosted: Sat Aug 21, 2021 4:33 am
This week's question is about a misunderstanding regarding the arc flash hazard. 1.2 cal/cm2 is the commonly referenced incident energy level where arc rated PPE is required. Because of this value, some have stated that an arc flash hazard does not exist below this value - I've seen this on labels in the past.
Below is a short piece that I wrote a few months ago on the subject which leads us to this week's question.
No Arc Flash Hazard Article?
Yes
No
It Depends
N/A
 Post subject: Re: Arc Flash Below 1.2 cal/cm2?
PostPosted: Mon Aug 23, 2021 7:32 am
A basic uniform of 8cal/cm^2 ensures clothing will not melt or continue to burn after arc extinguishes. Requiring employees to change clothes affects productivity and will lead to compliance mistakes.
