It is currently Thu Aug 13, 2026 8:05 pm
 Post subject: Arc Flash reduction kirk keys
PostPosted: Thu Oct 13, 2011 9:17 am
Cool new idea from URC, the Quick Trip (Arc flash reduction switch) for AC PRO can now be activated with a kirk key, which you interlock with all of the feeder breakers downstream.
Ensures you have your reduced arc flash settings enabled before racking out any breaker in that substation. Good idea, I like it. :cool:
PostPosted: Fri Oct 14, 2011 7:53 am
Do you have a site to look at this?
PostPosted: Tue Oct 18, 2011 6:01 am
They don't have it posted yet but if you PM me your email address I can send you the PDF, it is 2 MB so I can't post it.
PostPosted: Fri Jan 06, 2012 8:01 am
Kirk key infomation
Hello Zog,
Would it be possible to send me the site information as well. I'll later fill out my profile, in short I'm a electrical technologist given the task to try to find alternate methods to reduce the arc flash (cal's) on board vessels, with a confined control room.
Thanks for any information that you can pass on.
colp
PostPosted: Tue Jan 17, 2012 12:50 pm
http://www.utilityrelay.com/PDFs/QT_Datasheet.pdf
PostPosted: Fri Jan 27, 2012 7:46 am
stefancb4 wrote:
This is great. Thanks!
