It is currently Fri Aug 14, 2026 7:58 am
 Post subject: Size for Arc flash labeling
PostPosted: Mon Sep 14, 2020 9:27 am
Hello, good morning, this a exist one standar for regule the size in the arc flash labeling (for example 4" x 6", 6" x 6", etc.)
Excuse me, my english is not perfect.
 Post subject: Re: Size for Arc flash labeling
PostPosted: Wed Sep 16, 2020 7:47 am
There is no standard size.
As Mike said, 4 inches by 6 inches is commonly used.
PostPosted: Mon Sep 21, 2020 2:37 pm
Hello, my plant's labels are all around 5-1/4" x 4"
PostPosted: Tue Sep 22, 2020 4:52 am
I typically use 4" x 6". However, these won't fit on some of the smaller disconnects. In that case, I use a 2 1/4" x 3" label.
PostPosted: Tue Sep 22, 2020 6:44 am
What really matters is that the label font is large enough to be read, and that the labels are put on the device where they are easy to see.
PostPosted: Mon Sep 28, 2020 8:03 am
Hello Nerf,
as per the others the 4" x 6" is very common. However you have to remember that there is allot of us baby boomers out there in which our eyesite is challenged. Take a look at your work force and see what the average age is of the workers who would be referencing the labels and make your decision from there. I hope that this helps
PostPosted: Tue Sep 28, 2021 10:25 am
I use 4"x4" with the minimum info - bigger labels may not fit on small equipment
PostPosted: Fri Jun 09, 2023 10:50 am
I know this is an ancient thread but for future reference ANSI Z535.4 has a table of recommended letter heights vs viewing distance.
