It is currently Sat Oct 24, 2026 6:05 am
 Post subject: In-service component displaying as de-energized when cloned
PostPosted: Thu Apr 19, 2018 10:25 am
Just curious why a component (fuse, wire, bus/panel) when placed as new components shows in-service and energized but when cloned the bus shows de-energized until the next load is drawn on the model?
Somethnig I find annoying to the flow of building the model. I am sure it is user error.
Tim
 Post subject: Re: In-service component displaying as de-energized when clo
PostPosted: Thu Apr 19, 2018 12:54 pm
Haven't had that problem.
I have had on occasion a cloned bus lose its connection and I have to re-connect it to the cloned cable but never gone from in service to out of service.
Must be a setting of some sort.
Sorry.
PostPosted: Sun Apr 22, 2018 5:49 am
I would think that the reason is because you just copied/pasted and still need to edit it anyways (fix all the labeling, settings, etc.), so it's a great way to remind you to review everything in the cloned branch before it goes live in the model.
