| Author |
Message |
pramod mane
Post subject: Mitigation to "FCT not determined" pop up in ETAP software Posted: Tue Oct 15, 2013 12:37 am |
i am performing the arc flash study as per IEC standard for one of the project using E-tap Software. while running arc flash calculation "FCT not determined " pop is showing in the One line diagram. could you guide to mitigate the problem.or any changes to be made in the bus data, ort relay data. could you provide the any project report file for the arc flash study.
| Top |
wbd
Post subject: Posted: Tue Oct 15, 2013 5:17 am |
| Plasma Level |
Joined: Wed May 07, 2008 5:00 pm Posts: 881 Location: Rutland, VT
Not sure what that means as I use a different software but I would think that you could find out what that means by consulting the Help section of your software. Did you look there?
_________________ Barry Donovan, P.E. www.workplacesafetysolutions.com
| Top |
Jim Phillips (brainfiller)
Post subject: Posted: Sun Oct 20, 2013 3:05 pm |
| Plasma Level |
Joined: Mon Sep 17, 2007 5:00 pm Posts: 1738 Location: Scottsdale, Arizona
FCT = Fault Clearing Time? Just a guess
_________________ Jim Phillips, P.E. Brainfiller.com
| Top |
Girish
Post subject: Posted: Sun Oct 20, 2013 10:26 pm |
Joined: Mon Oct 08, 2012 2:59 am Posts: 24 Location: India
pramod mane wrote: i am performing the arc flash study as per IEC standard for one of the project using E-tap Software. while running arc flash calculation "FCT not determined " pop is showing in the One line diagram. could you guide to mitigate the problem.or any changes to be made in the bus data, ort relay data. could you provide the any project report file for the arc flash study. Please follow the link http://etap.com/support/faq-pdfs/ETAP-FAQ-arc-flash-calculations.pdf Regards Girish
| Top |
Page 1 of 1
[ 4 posts ] |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
