| Author |
Message |
JBK89UT
Post subject: Short Circuit Rating of Equipment less than 50Vdc Posted: Fri Sep 21, 2012 5:51 am |
Joined: Thu Oct 27, 2011 5:00 pm Posts: 5 Location: Vermilion Ohio
I have been asked by my customer how does the NEC apply to a -48VDC system (Gov't office). The question relates to short-circuit rating of equipment feed by a -48VDC battery back-up system. If I remeber correctly the NEC excludes low voltage systems (<72V), which it does not governn, but I can not find this within teh NEC code book. Can anyone asist? Thanks Jack
| Top |
JBD
Post subject: Posted: Mon Sep 24, 2012 2:15 pm |
Joined: Mon Jan 18, 2010 11:35 am Posts: 619 Location: Wisconsin
Effectively, the NEC covers all voltages. It does have a section on power limited systems which has limitations on voltage (usually <30VDC) and current. It is only NFPA70E that has a defined cut off.
| Top |
Page 1 of 1
[ 2 posts ] |
