It is currently Sat Oct 03, 2026 10:22 pm
Which Classes of lasers does your company/clients have?
Class 1 18%  18%  [ 9 ]
Class 1M 8%  8%  [ 4 ]
Class 2/2M 20%  20%  [ 10 ]
Class 3/3R/3B 16%  16%  [ 8 ]
Class 4 10%  10%  [ 5 ]
Not sure 14%  14%  [ 7 ]
None 16%  16%  [ 8 ]
Total votes : 51
 Post subject: NFPA 70E Article 330 Safety-Related Work Practices: Lasers
PostPosted: Sun Nov 06, 2022 3:06 pm
NFPA 70E Article 330 Safety-Related Work Practices: Lasers applies to work practices for maintaining lasers and their associated equipment.
Lasers systems are classified by output power and wavelength and are:
Class 1: incapable of producing damaging radiation levels during operation. Example: DVD players and laser printers
Class 1M: incapable of producing hazardous exposure conditions during normal operation unless the beam is viewed with an optical instrument.
Class 2/2M: Emits in the visible portion of the spectrum and eye protection is often from the aversion response – blinking, looking away. Example: laser pointers.
Class 3/3R/3B: Hazardous if viewed directly but is considered safe if handled carefully with restricted beam viewing. Example: DVD writers.
Class 4: Can burn the skin or cause permanent eye damage as a result of direct, diffuse or indirect beam viewing. Can ignite combustible material. Examples: Industrial, scientific, military and medical use.
The question: Which Classes of lasers does your company/clients have?
Class 1
Class 1M
Class 2/2M
Class 3/3R/3B
Class 4
Not sure
None
Select all that apply
