Arc Flash Forum
is arc flash catagory reduced?
https://brainfiller.com/arcflashforum/viewtopic.php?f=7&t=266
Page 1 of 1
Author:  betabar [ Mon Dec 08, 2008 11:39 am ]
Post subject:  is arc flash catagory reduced?
When a mcc bucket is locked out does this affect the flash catagory rating? example a bucket rated a cat 3 is locked out do you still need cat 3 ppe to open the bucket to view the unit?
Author:  Zog [ Mon Dec 08, 2008 1:16 pm ]
No it is not, the hazard exists from what is upstream of the MCC so locking it out changes nothing in that cell.
Author:  haze10 [ Mon Dec 08, 2008 7:04 pm ]
Arc Flash is about working on or near live parts. The only problem with a locked Mcc bucket is that it is only deenergized on the load side of the breaker or fuse switch - the line side is still energized. If the designed incorporated some type of shield or guard that prevented touching live parts then I think you could make a case for it being outside of AF requirements.
http://www.phpbb.com/
