It is currently Thu Aug 13, 2026 9:47 am
 Post subject: 30" leg coveralls
PostPosted: Sun Feb 21, 2010 7:24 am
Where can we purchase coveralls with different leg lenths? I purchased 2 pair [ large ] and could not get ones with short leg ,29" 30" only 34".
PostPosted: Fri Mar 05, 2010 10:32 pm
When purchasing coveralls they are sized more in the full body length because they are one piece. For instance most styles are 5'8" to 5'11 1/2" for regular length and 6'0" to 6'3" for talls.
Also the crotch hangs down a couple inches so if your inseam is 29" you would only need about 27".
If your height is 5'3" to 5'7" you would take a short length.
We sell different brands and some of them come in the short length which I could help you out with.
PostPosted: Mon Mar 15, 2010 9:55 am
Workrite makes coveralls in regular, short and tall. The regular has a 30" inseam, the short has a 29", and the tall has a 31". We can also alter to your requirements. By contacting customer service at 800-521-1888 you can find out the specifics.
PostPosted: Mon Mar 15, 2010 1:02 pm
Just be sure that any alterations made are done so using the FR thread. I have seen non FR thread used in many garments when alterations were made that can be a serious hazard and non-compliant.
PostPosted: Tue Mar 16, 2010 10:26 am
In reply to the comment from Zog, he is exactly right. Workrite only uses FR thread, but that may not be the case for others doing alterations.
PostPosted: Wed Apr 21, 2010 7:46 pm
The FR coveralls tend to be worn over your existing clothing which is why manufactures tend to stitch them shorter. We also carry Nomex & Protera coveralls at various lengths for the inseams, if you have any questions please do not hesitate to contact us. We also offer alteration tailoring with Nomex thread.
