It is currently Sat Oct 10, 2026 5:36 pm
 Post subject: Fused Leads for Multimeters
PostPosted: Tue Sep 22, 2009 10:10 pm
I have heard both sides of the argument as far as implementing either fused or unfused leads. My company is currently looking at creating a standard for all meters for work on 575v and below in our facility will need to use 1000 V Cat III meters and there is discussion on what should be spec'd for the leads.
What is everyone's beliefs/understanding of which is the safer item to have.
Obviously, the fused leads can protect a meter better than an unfused set, however if the electrician decides to forgo the "test on known voltage, test on desired equipment and then retest on known voltage"; which we all know does happen from time to time, the fused leads could present a much greater life threatening hazard.
I've heard different advise from different people within the same agencies/groups advocating each of the two. I don't know which to fight for and I'd appreciate any feedback.
Best regards.
PostPosted: Wed Sep 23, 2009 12:29 am
Best regards.
The leads should be marked CATIII also, no reason for them to be fused when used with the CATIII meter they are designed to be used with.
