| Author |
Message |
Jim Phillips (brainfiller)
Post subject: Data Collection Form/Checklist Posted: Sun Dec 04, 2022 12:44 pm |
| Plasma Level |
Joined: Mon Sep 17, 2007 5:00 pm Posts: 1738 Location: Scottsdale, Arizona
This one is simple but there is an underlying reason for the question (committee work)
Do you/company/client/consultant use a data collection/checklist form? Yes No N/A
Your thoughts are welcome!
| Top |
bbaumer
Post subject: Re: Data Collection Form/Checklist Posted: Sun Dec 04, 2022 3:59 pm |
| Arc Level |
Only if I don't have a one-line prior to survey.
I like to at least build the model off the existing single line diagram prior to surveying if it's available. Even better if I have shop drawings on the equipment and a power plan.
Field survey is mostly verification that I mark right in/on the model.
If neither are available and I have to collect all the data before modeling anything I have a form on my iPad for data collection with hard copy forms in my backpack as a backup plan.
Edit: it also depends on the size of the job. Very large models can be a little unwieldy on scene so sometimes forms are better depending on the amount of survey needing to be done.
_________________ Retired but I might visit once in awhile
| Top |
Page 1 of 1
[ 2 posts ] |
