It is currently Fri Nov 06, 2026 6:17 am
 Post subject: Arc Flash PPE
PostPosted: Thu Mar 21, 2024 6:30 am
Hi! I’m Phil. I’m the Safety Coordinator at a textile plant. Been here 1 year. I’m looking to learn. We are reviewing the Arc Flash Program. Again, I’m learning as I go. I bought the NFPA70 National Electrical Code (2023). Having trouble really understanding the material, but I’m trying…I cannot find anything concerning Arc Flash PPE. I come across this forum and found a table referenced in130.7(c).The problem is that my NFPA70 book goes from 110.79 to 200. Anyone have any tips?
Phil
 Post subject: Re: Arc Flash PPE
PostPosted: Thu Mar 21, 2024 7:37 am
You need NFPA 70E - 2024. Much more helpful than the NEC as far as arc flas PPE goes.
Also, watch all of Jim's videos on Brainfiller.com and/or YouTube.
PostPosted: Thu Mar 21, 2024 7:41 am
NFPA 70E, Standard for Electrical Safety in the Workplace, 2024 Edition https://a.co/d/0pE59f7
NFPA 70E, Handbook for Electrical Safety in the Workplace, 2024 Edition https://a.co/d/68fcEZ4
The Handbook is a little nicer to have if you can afford it because it has more explanations.
