| Arc Duration - Fuses or Circuit Breakers? https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=5432 |
Page 1 of 1 |
| Author: | Jim Phillips (brainfiller) [ Sun Mar 28, 2021 2:54 pm ] |
| Post subject: | Arc Duration - Fuses or Circuit Breakers? |
The arc flash duration has quite an impact on the incident energy. It is normally defined by how long it takes an upstream protective device to clear the fault. This week’s question is about whether your company/clients use fuses (assumed to be current limiting) or circuit breakers. I reference power distribution circuits to distinguish from control circuits Does your company (or clients) use circuit breakers or fuses for power distribution circuits? Circuit Breakers Fuses We use both Depends on the client N/A |
