It is currently Wed Nov 11, 2026 1:05 am
Do you believe switches should be open to view the blades even when the line side is energized?
Yes 31%  31%  [ 15 ]
No 31%  31%  [ 15 ]
It Depends 39%  39%  [ 19 ]
Total votes : 49
 Post subject: Electrically Safe – Visually Verify Blades
PostPosted: Sun Apr 10, 2022 3:06 pm
120.5 Process for Establishing and Verifying an Electrically Safe Work Condition
(3) Wherever possible, visually verify that all blades of the disconnecting devices are fully open..�
Viewing the disconnect blades is easy if the switches have viewing windows. However most switches do not have windows. In a recent discussion, the subject came up regarding opening disconnect switch covers to view the blades - it was an interesting exchange. An obvious issue is the line side would likely be energized and exposed. Also, remember most equipment is old/legacy equipment.
Here is the question:
Yes
No
It Depends
