It is currently Wed Nov 11, 2026 4:38 am
Does your company (or clients) use circuit breakers or fuses for power distribution circuits?
Circuit Breakers 18%  18%  [ 7 ]
Fuses 3%  3%  [ 1 ]
We use both 51%  51%  [ 20 ]
Depends on the client 28%  28%  [ 11 ]
N/A 0%  0%  [ 0 ]
Total votes : 39
 Post subject: Arc Duration - Fuses or Circuit Breakers?
PostPosted: Sun Mar 28, 2021 2:54 pm
The arc flash duration has quite an impact on the incident energy. It is normally defined by how long it takes an upstream protective device to clear the fault. This week’s question is about whether your company/clients use fuses (assumed to be current limiting) or circuit breakers. I reference power distribution circuits to distinguish from control circuits
Circuit Breakers
Fuses
We use both
N/A
