It is currently Mon Oct 26, 2026 11:36 am
When establishing an electrically safe work condition, do you also apply grounds to the circuit?
Yes 4%  4%  [ 1 ]
No 29%  29%  [ 8 ]
Depends on the situation 68%  68%  [ 19 ]
Total votes : 28
 Post subject: Grounding the circuit
PostPosted: Sun Mar 04, 2012 8:38 am
  • Yes
  • No
  • Depends on the situation
PostPosted: Mon Mar 05, 2012 12:14 pm
We don't bother earthing out LV circuits but anything MV and above is not deamed Isolated until earths are applied to the circuit.
Dave Sargent
Origin Energy NZ
PostPosted: Fri Mar 16, 2012 10:55 am
i second what Dave said...we'll perfrom voltage checks on the LV side and then ground out the MV systems.
PostPosted: Fri Mar 16, 2012 9:22 pm
Has much to do with context. Some facilities are more comfortable with a visible open; i.e: withdraw the breaker; but on systems with overhead distribution lines (exposure to accidental energization or induced voltage) grounding is the norm, always.
