It is currently Tue Nov 10, 2026 8:57 pm
 Post subject: Reduce Arc Flash Accidents Using Totally Integrated Automation
PostPosted: Sat Jan 28, 2012 1:48 am
An article in Design World, written by the Design World staff, describes the sad results of several arc flash explosions, and discusses how a Totally Integrated Automation (TIA) architecture created by Siemens can provide information that helps reduce exposure to potential arc flashes. The article states:
"By integrating all the relevant equipment, such as the motors, drives and switchgear, with the communications network in what Siemens calls a Totally Integrated Automation (TIA) architecture, operators are able to monitor and pull diagnostic information, perform trend and root cause analysis and generally better see what the problems are before sending an electrician into the plant to deal with a problem. Over time Richards found that workers were going into the electrical cabinet less and less often."
[url='http://www.designworldonline.com/ArticleDetails.aspx?id=4429']Read the article here[/url].
Related Past Posts
[url='http://www.labelprinters.org/blog/2006/11/being-prepared-involves-wearing-right.html']Being Prepared Means Wearing The Right Clothing[/url]
[url='http://www.labelprinters.org/blog/2007/01/arc-flash-protection-in-mining-industry.html']Arc Flash Protection In The Mining Industry[/url]
[url='http://www.labelprinters.org/blog/2007/06/is-your-electrical-ppe-adequate.html']Is Your Electrical PPE Adequate?[/url]
$70 value free! 130 page [url='http://www.arcflash.me/gift-arc-flash-handbook.php']Arc Flash Solutions Handbook[/url]. This handbook will walk you through the necessary steps for implementing an arc flash assessment as part of your overall safety program requirements.
[url="http://feedproxy.google.com/~r/Nfpa70e/~3/ND6_o6_HLZQ/reduce-arc-flash-accidents-using.html"]Continue reading...[/url]
Arc Flash Forum News Feed
