It is currently Wed Nov 11, 2026 2:33 am
 Post subject: SKM Modelling-Load
PostPosted: Sat Sep 23, 2023 8:51 am
I want to model an RTU (rooftop unit) HVAC in SKM. As per the nameplate, it has both motor load (constant KVA) and non-motor(constant Z) load. Is there any option in SKM to model both motor and non-motor loads together like a lump load? I have seen this option in other simulation software. I wanted to confirm this in SKM.
 Post subject: Re: SKM Modelling-Load
PostPosted: Wed Oct 11, 2023 1:36 pm
Why not just connect a load and a motor to the same bus? It's effectively the same thing.
