It is currently Thu Oct 01, 2026 5:48 pm
 Post subject: CT Ratio
PostPosted: Thu Aug 19, 2010 9:16 am
What does the following CT ratio feeding an 87T Differential Relay mean?
600/100-5
Do I use the 600 or the 100 as the primary ratio?
PostPosted: Thu Aug 19, 2010 9:21 am
600/100-5
How many leads are coming out of the secondary? It may be a multi-ratio CT. MR 600/5 conn 100/5.
PostPosted: Thu Aug 19, 2010 1:34 pm
This is generally what the underlining means.
PostPosted: Mon Aug 23, 2010 7:05 am
Thanks guys for the info. After some digging I found that it was a Multi-Ratio (MR) CT with the 100 lead selected.
