It is currently Sat Apr 18, 2026 3:38 am
 Post subject: Suspension fault on my L405 and I'm too scared to take it ju
PostPosted: Mon Apr 13, 2026 6:16 am
Alright so my 2016 full size RR decided to throw the dreaded "suspension fault normal height only" message on the dash this morning right as I was pulling out near Corniche and the front passenger corner is now sitting just a touch lower than the rest of the car after parking it for a few hours. I've had the thing for three years and I knew this day was coming because we all know the air struts on these British trucks are basically a consumable item out here in the heat and humidity but I'm really trying to avoid the main dealer diagnostic fee that just gets you a quote for replacing every single component in the system. I need someone who actually knows the difference between a simple valve block leak and a compressor on its last legs without throwing parts at it, you know the kind of shop where they actually rebuild the strut instead of just selling you a new one for the price of a small used Japanese car. I keep seeing the phrase Range Rover Expert Repair Abu Dhabi pop up in my searches and I'm curious if anyone has a real solid indie garage they trust with the air suspension specifically because I'm not trying to have a perfectly good compressor burned out by a bad leak diagnosis. Any names or places in Mussafah you guys would let touch your own L405 would be a lifesaver right about now.
