It is currently Sat Nov 07, 2026 4:13 am
 Post subject: 2015 NFPA 70E Proposals Development - Group Effort
PostPosted: Sun Apr 22, 2012 2:46 pm
[SIZE=3]2015 NFPA 70E Proposals Development - Group Effort[/size]
[SIZE=3]Many requests have been made to use the Arc Flash Forum as a place to develop proposals (now called public input) for the 2015 edition of NFPA 70E. Many forum members have great ideas for improving this important standard but are not in a position to make a formal submittal to NFPA.[/size]
[SIZE=3]This area will be used to collectively develop public input (proposals) for the 2015 Edition. If you have a specific section in the 2012 Edition that you feel needs changed, please begin a new thread for each change/suggestion.[/size]
  • [SIZE=3]Each proposal must have its own thread.[/size]
  • [SIZE=3]Each thread will be where a proposed change is discussed and debate[/size]
  • [SIZE=3]Proposed text, rational for the change / addition / deletion, supporting data, substantiation should be discussed since this is part of the public input form from NFPA[/size]
  • [SIZE=3]Ultimately we should have new / revised text for the proposal[/size]
  • [SIZE=3]To determine which proposals are submitted from the forum, a vote will be taken among all members towards the end of May based on the groups proposals.[/size]
[SIZE=3]Proposals that receive significant support from Arc Flash Forum members will be submitted to NFPA prior to the June 22, 2012 deadline.[/size]
[SIZE=3]A small group did this on a limited scale for the 2012 Edition with some success. Opening this up to all with an interest in electrical safety will hopefully help the continued improvement of the next edition.[/size]
PostPosted: Sun Apr 22, 2012 3:08 pm
Nice Idea!
PostPosted: Mon Apr 21, 2014 7:18 am
Jim, I may be a little late in getting in on this, but your post shows a posting date of Apr 22, 2012, with a deadline of June22, 2012, for the NFPA 70E 2015 Edition. Are these dates correct? They are nearly two years in the past.
PostPosted: Mon Apr 21, 2014 1:43 pm
Yes, the June 22 NFPA deadline is correct. Since NFPA 70E is on a 3 year revision cycle, the call for proposals (public input) comes early in the cycle. There is a lot of work that happens after the close and the 2015 edition is almost ready for release later this year. And then.... the whole process begins again.
PostPosted: Mon Apr 21, 2014 1:58 pm
It wasn't the June 22 date I was questioning as much as it was the 2012 year I was questioning.
