It is currently Wed Oct 28, 2026 4:21 am
 Post subject: Fuse - can't view TCC
PostPosted: Fri Sep 17, 2010 11:39 am
Hi, I am using ETAP 7.1 with the server license and have problems with fuse tcc. I have big problems seeing fuse TCC. Sometime everything works fine but other time, when i try to view the same fuse tcc, it is simply showing a blank page. Even when I manually trace a tcc, it will sometime work, other time not. Breaker and relay tcc are working fine. It is causing me problems because when it shows me a blank page, the fuse is not taken into account when performing Arc flash analysis... Anyone got that problem ?
thanks.
PostPosted: Sat Sep 18, 2010 5:00 am
Sounds like the fuse isn't selected. Make sure the fuse is selected in the OLV before running the tcc.
