It is currently Thu Nov 12, 2026 4:58 pm
 Post subject: Documents that list Shock Protection approach boundaries....
PostPosted: Tue May 11, 2021 2:50 pm
Hello Everyone,
As many of you are aware documents like NFPA 70E 2021 publish shock protection boundaries for energized equipment(See image sampled from NFPA 70E).
After doing some research I saw that there is more than one document out there with shock protection boundary recommendations.
Some examples of documents that also publish Shock Approach boundaries are listed below:
Brazil: NR-10
(http://www.braziliannr.com/brazilian-regulatory-st...)
Canada: Z462
Great Brittan: EN 501110-1:2013
Im curious if anyone out there knows of other documents similar to the samples I listed above especially if there is one that used out in Australia that differs from NFPA 70E.
Any help with this inquiry would be much appreciated!
Shock.tif
